new optimus
Android Expert
Im assuming its because its for metro.@ ed2000 I installed the energy rom but get a "not installed" error when trying to install the metro mms fix apl...
i tried that and the epst doesnt work properly in this rom. mms doesnt work but vmail works great.I dont know anything about your "flash" to boost but did you open the dialer and go to the menu that changes your mms@ settings to boostmobile?
I will get you the specific info but off the top of my head I cant think of it.
Ok found it check this and make sure its correct.
If you are using cm7 or other non-sense rom(no pun intendedi tried that and the epst doesnt work properly in this rom. mms doesnt work but vmail works great.
) you will need to use go sms pro and in settings set the url for mms.
