I stopped reading responses after a few posts, but to clarify a few things;
Android's su binary doesnt allow users to take root privs. Rooting replaces the su binary with one that can be invoked by users/apps similar to using sudo. It also installs several utilities that are usually associated with root level access/activities.
Rooting has been known to block updates on some phones, nut can be undone.
If you want to load ROMs you'll need to replace the bootloader as the stock one only supports installation of signed packages (no third party). In order to do that you have to unlock the bootloader, which voids the warranty and cannot be reversed.
Cyanogen can be thought of as a distro that is built from AOSP source code. It is known as being very stable and fast. Version 7 is based on Gingerbread. Version 8 will never be released/developed since Google never released source code for Honeycomb. Version 9 is thought to be based on ICS, when the source is released of course.
One last point is that Motoblur runs somewhere between the kernel and user land. Many view it as a detriment but it's what allows features like webdock and dock audio to work.
