hbk129
No problem with Netflix works flawless on 3G and wifi. Loads noticeably faster.
Really? That makes me wonder what % of us are having the issue.
broke tap feature to correct in swype
removed options when pressing power key to silence turn off mobile etc
changed font on some screens
broke Netlix
only cut paste options when highlighting instead of cut paste search share etc.
Seriously if I could get rid of it I would.
Has anyone else noticed how QUICK the phone shuts off, and then powers back on ?
I am not referring to the new restart option.
dag... i just turned it off for the first time since the update.. it did shut off faster than pre update..
but DAG... i pressed the power button.. i vibrated... the sprint cheesy logo STARTED but a half second later the blasted home screen was up! LOL... i could not even swallow my spit that fast...
this update really breathed new life into this tired old june 2010 launch day version 2 evo...
That's due to the new "Fast Boot" option under Applications settings.
I found something new:
Go to -
Menu - Settings - Battery - Battery Use
There is now a 'graph' up top that you can click on and shows your battery usage![]()
Regarding the notifications and Handscent, I couldn't turn off the stock app's notifications either (apparantly there is a way, I didn't research too much), but what you can do is turn off Handscent's notifications. When the stock notification comes up, the phone should ask you what application you want to use, and from there, you can tell it to always use Handscent. The only downside to this is that for whatever reason, when there are multiple text notifications, it will open with the stock app instead of Handscent in my experience.
As a general troubleshooting tip:
for a particular app that's not behaving properly, go to Settings > Applications > Manage Applications, choose the app, and clear the cache and data for that app. It means you may lose your settings for that app, but manually set them up again and see if that fixes things.
This may or may not resolve your issue, but it's always a good first step in troubleshooting any issue.
I don't see Battery or Battery use in the settings area.
I wonder if the phone is really shutting off, or perhaps just "sleeping" of some sort, as you dont see the white HTC EVO 4g Splash screen come up....(not to be confused with the yellow 4g splash animation that follows)
This is unfortunate. Anyone know another way to get Swype to correct a word?broke tap feature to correct in swype
