Ok, I know you think that my link earlier in the thread did not work, but the keyboard you are using is proof that it did. If you want those extra features, go back to the Market and pay $.99 for the full app rather than the free one you are using. It will appear as Gingerbread keyboard in your input options.
http://tinyurl.com/3h8zdns <If you don't want to scroll back to the prior post.
http://tinyurl.com/4y4ctsx <Paid version.
Regarding the notifications and Handscent, I couldn't turn off the stock app's notifications either (apparantly there is a way, I didn't research too much), but what you can do is turn off Handscent's notifications. When the stock notification comes up, the phone should ask you what application you want to use, and from there, you can tell it to always use Handscent. The only downside to this is that for whatever reason, when there are multiple text notifications, it will open with the stock app instead of Handscent in my experience.Yea I have been using the stock app because I have no idea how to turn off the notification of the stock app to use handcent.
Also my phone had the ability to call people which I did not want - lets say I would want to call my brother and instead it will call a random person from my contact list even though I did press on my brother's phone number. Just weird!!!
Do you need to have the previous update installed before you can get Gingerbread? When I try to get the update, I am only being offered with 3.70.651.1, which I didn't want before due to the multiple issues a lot of folks had with it. Has anyone been able to get the new one without having to previously install 3.70? Thanks!
Im a guy and I actually did dload it and did not realize it was working.
Check the other gingerbread thread for the link
I went to HTC Software update, hit the "check now" button and it said "update available." I remebered I didn't have wi-fi on so I exited, turned on wi-fi, came back and hit the 'software update' again and now it keeps telling me 'your phone is up to date, no updates available for your phone"
Did i bork myself?
Another keyboard as an option would have been cool.
Did anybody hard reset? Debating whether I should or not and there are some apps that are no longer on the market, but I can't back up because they're on the phone and can't be transfered to the SD.
Also, I had about 20 of my App shortcuts lose their icons, reverting to a generic Android green android guy with the appropriate text underneath. I trashed them and replaced them with fresh shortcuts, and all was well.
I'm thinking it does. Maybe we both are dumb? hahaIs it me or does the battery charge faster after the update? MIGHT be my imagination but my battery was dead an hour ago, now it's almost charged.
Same here, but when I did a restart it happened again. Also because I only have 39MB free I can't update any on my apps!![]()
ShootMe was never supposed to work on an unrooted Evo -- whatever the reason is that it worked is essentially an open exploit, so for better or worse, it's the right thing that it's closed up now.
link please!!There is an equalizer that works with Gingerbread on the market for those may be interested.
