i would like to know if you can flash [ROM] GingerSteem Extreme II on the zvb verison or do you need to be on a rooted zvc version?
so i can use this rom? my device is zvb... i heard about market problems. and is it still overclockable?Yes, you can flash it. Just dont flash any of the kernels posted on here otherwise your phone will bootloop. (For now, only the kernel with the rom is ZVC, the other kernels are not ZVC based yet.)
so i can use this rom? My device is zvb... I heard about market problems. And is it still overclockable?
you really need to edit the thread title so ppl dont think this is a ROM thread![]()
OUCHyou really need to edit the thread title so ppl dont think this is a ROM thread![]()
im sorry.. i asked in the orginal thread and no one replyed really... how do i change the name ive been trying todo it for the past hour... im not trying to cause any trouble. just how do i change the name
is that a fine title?Go to the OP and edit then change the "Title" of the post![]()
Maybe someone can clarify for me. Ok, so if I am currently ZVB, I can still pull down the latest GSE II with no problems (just don't get creative with the kernels). But is ZVC something that I can change or am I always stuck at ZVB? And if ZVC is do-able, could someone point me to the appropriate psoting that will point me to success?
