Already installed![]()
Seems fine so far, no fix for the notifications area bug though as mentioned above
But if you put the status bar at the bottom you can use the home key to show/hide notifications in LauncherProYeah as far as I can see, all that's been added is tablet options giving you the option to put the status bar at the bottom and disable the lock screen
No offence to the devs, they are unpaid after all but wouldn't it make more sense to fix bugs before adding new features?
Well if CM / RT dont know about the bug...
I've seen little of this bug, and pretty much all I have seen is on this forum. If Richard missed a post on XDA or no one brought it to the attention of the CM team, its possible it wont get fixed.
It may be worth someone who knows about this bug trying cm7 to see if it is reproducable.
Richard may not have seen the bug because it depends how you use the phone as to whether you see the bug or not.
For example, I use swipe gestures to show / hide the status bar and do not have a problem so I only have your word for it (which of course I believe) that this bug exists. Same with many bugs I see reported.
I have 2 docks. 1 with invisible icons and set swipe on all 5 of those.
Then on the dock with visible icons, just the app drawr swipes for status.
Is it worth flashing the ManU kernel for battery or does GV2.0 default kernel do just as good a job?
Well like you I don't actually use this setting, but I was getting frustrated with my work so did a little playing. Conclusions are:It may be worth someone who knows about this bug trying cm7 to see if it is reproducable.
1) It's in the CM7 release as well.
2) It's been fixed in CM7 nightly 39.
So we can safely assume that the fix will appear in GV in due course.
Oh, and flicking down the notifications is faster in CM7 nightly 39 than in the release or GV 1.9/2.0.
But I'm restoring back to GV now...
