Help gmail holidays et al calander question
shantytownbrown
I added some events calanders on my gmail calander on the net (eg us holidays, sports teams schedules)
they are not however showing up on my Evo even after sync'ing with the cloud...
how come i cannot see them on my mobile?
thanks in advance
scott
Clear data for calendar. Make sure you have the most recent version of gmail and then open calendar hit menu.more.refresh i think is the order.
Also make sure you haven't turned off the auto sync in accounts and sync. Many have done so when adjusting settings for battery life.
silly question but, how do you clear calader data...?
and i am using the stock EVO calander, should i be using something else...
scott
thanks so far by the way...
Menu.settings.aplications.manage applications.all
Look for something that says calendar
found it, cleared all app data in ones that said "calander"...then refreshed as you suggested...
but..still only pulling up the entries I put in, not the "add-on" holiday calanders i subscribe to...
any other ideas?
while calendar is open press exactly as he listed.
it is there...or there is something wrong with your calendar app.
try going to market and searching "gmail" and install the most current gmail
since release that menu has been there on mine tho
got it now, but you guys missed a step (no worries, i found it)...
menu-->more-->calandars
then once on that page
menu--->add calendar...
ok so i can add US Holidays, Sunrise/sunset, but it is giving me the NHL, NBA, NFL, MLB schedules i subscribe to on my online gmail calendar in the list of choices...
thanks so far..
thanks so far..
meant to say that it IS NOT giving me the options to choose the sports calendars to which i subscribe...(i typo'd)
the US holidays, sunrise/sunset are others i subscribe to just tlike the sports ones...
