Gnex or Moto Razor
Whatstreet
My wife wants a smart phone and we have VZ. I'm thinking about getting her the Gnex or the Moto Razor.
Which one is best and why?
Not sure if serious. Gnex is the best phone, razr came out like 4 years ago and is a feature phone bro.
/trollinhard
I'm pretty sure the OP is referring to the Droid RAZR. The original RAZR was released 7 years ago, not 4.
To answer the original question, IMO I would definitely go with the Gnex. Motorola droid phones have been plagued with problems.
The phones are aimed at completely different audiences IMO.
The Nexus is going to have a much larger learning curve, and is a great phone for those familiar with Android, and plan on rooting and running custom ROMs, and kernels. Definitely would be my choice if I were in the market for a new phone right now.
However, out of the box, the Razr is going to be easier the use and being quite a bit thinner would be easier for someone with smaller hands. If she has no plans on rooting, or you don't want to root and maintain the phone for her, I'd go Razr hands down.
Best thing to do would be to go to a VZW store, play with both of them and let her decide which one she likes better.
I'm gonna guess you'll be coming home with a Razr, or Rezound, which would be another good choice.
Go look at the Nexus forum and you should find plenty of threads with people complaining about poor signal and battery. It reminds me of the Thunderbolt when it released. I stuck it out with HTC and bought the Rezound and I'm getting 4G signals where I wasn't on the Thunderbolt. It seems that HTC learned its lesson with the Thunderbolt. Just about every complaint I had with my old Thunderbolt has been addressed. Below are the speeds I'm getting at home where all I could manage on the Thunderbolt was 3G (2-3 Mbps down and .5 up). You may also want to check this thread out http://androidforums.com/htc-rezound/469803-what-4g-speeds-you-getting-taking-my-gnex-back.html
25851d1324653525-what-4g-speeds-you-getting-taking-my-gnex-back-2011-12-23_09-15-48.jpg
Rezound all the way... Ha it'd be the one I would choose, going to get ics removable battery better reception hd screen great sound.
Oh and this as well as a removable SD card....
My .02 :
go to a store, play with both in store. The "thin" RAZR isn't THAT much thinner than the GNEX. For me, it felt more 'edgy" in my hand than the Nexus, so that was kind of a negative for me for the RAZR. The Nexus just felt more comfortable in my hand. Feature-wise, they're both very similar. The Nexus you can use an extended battery, as it's removable. But you can't expand the memory. BUT, you already get 32 GB inside, and most people aren't going to use it up.
Also keep in mind, that while there ARE threads on the forums with people having issues with the Nexus, that's the same with pretty much every new phone. Mine has been flawless since day one, and I've had no signal issues. It's been the same as I had with my Bolt, which was the same as every OTHER phone I've had. The people without issues aren't posting nearly as much as the much-smaller percentage of people that do.
The Rezound as mentioned, is also another good choice. Slightly faster processors, decent form factor, good specs all around. But, she is going to want to hold and play with each. Also not knowing what you and she are coming from already, it makes a little harder with not knowing your experience.
Each person will have their own preferences, and it's just a matter of finding yours/hers. Take everyone else's experience in the mix, but remember again, that for everyone person posting with a problem, there are countless more without any. And not every problem is something that isn't under construction, so to speak. Just like the Nexus has updates coming that will enhance things for some people, I'm sure the RAZR is in the same boat (in fairness, I haven't browsed on the RAZR forums at all).
Good luck with whichever you choose!
