Shawnsac2000
Go launcher EX with the blux as theme. Well when i click on a Icon there is a square orange box. How do i get field of the orange. Box or change the color?
Go launcher EX with the voice as theme. Well when i click on a Icon there is a square orange box. How do i get field of the orange. Box or change the color?
Nice video but did not tell me how to get rid of the orange square around the icons that i click on.
I like LP but GL lets you change icons w/o install another app to do itJust one of many reasons I keep going back to LP.
I'm asking because I'm not able to resize my widgets and no Edit or Replace button pops up when I touch on a widget or icon.
This may be a dumb question, but did Go Launcher EX replace the original Go Launcher? Like there's the ADW Launcher, then there's ADW EX? I didn't get Go Launcher when it originally came out, and the only thing I can find in the makret is the EX. I'm asking because I'm not able to resize my widgets and no Edit or Replace button pops up when I touch on a widget or icon. Do I need to change something in my Settings? Thanks for the help!
You can do all of the with GLEX
When I click on a widget, nothing pops up! No Edit, Resize, Delete...just the option to move it or drag to trash can.But how?? I've been in and out my Preferences like 50x and don't see what I need to change in order to resize themWhen I click on a widget, nothing pops up! No Edit, Resize, Delete...just the option to move it or drag to trash can.
I just sent an email to the Developer. Thanks anyway..If I may offer a tip,just on the outside chance that it might work.
I have Launcher Pro PLUS,& the way widgets are resized is by moving the widget around by holding your finger on it & literally forcing it up next to another icon or widget on the screen.When that happens,a 'frame' appears bordering/surrounding the widget.
Then,you can resize the widget,almost just like resizing an image in your GALLERY.Once the widget is to the desired size,press the BACK-UP(ARROW) physical button to set the newly resized widget.
If that doesn't work,try going to the developers website listed w/the app in the MARKET or drop the developer a line at his/her Email address. I've found most developers are very responsive to customer inquiries,regardless if you are using the free or paid version.
