Help Gold card for my Desire
nolia
I have been trying to create a gold card this morning with the SD card that came with the phone, I have downloaded all the required software but when I run command prompt it goes as far as
C:\AndroidSDK\tools>adb devices
'adb' is not recognised as an internal or external command, operable program or batch file
I have checked the usb drives using USBdeview and uninstalled and reinstalled but it just won't go beyond the point above. I am sure there is something I am doing wrong. Can you help me please?
1) depending on which version of the sdk depends on whether adb is in tools or platform-tools.
2) Just use the guide in the rooting FAQ to create a goldcard (link in my signature)
tried using platform tools and it worked. I am using a 4Gb card that came with the desire. I have tried downloading an update over the air but it won't update phone it just freezes and the a red triangle with an exlcamation mark appears, what am I doing wrong?
Couldnt tell you without knowi9ng current software version and the version you are updating to etc.
