Help Google Calendar: sync is currently experiencing problems. it will be back shortly.
Hi! I am new here!
Normally i would search google for solutions to my phone problems and so far they have worked. problem is I am really stumped on my current problem.
handset: Samsung Galaxy Note
problem: google calendar would not sync
1st occurance
error: calendar has stopped. twlauncher has stopped.
tried: resetting phone to factory settings
result: still won't update calendar
tried: resetting phone again!
result: did not work again
tried: deleting all yearly/monthly reccurring entries
tried: removing leap year birthdays (there were none really)
result: did not work still
tried: downloading Google Calendar App
I am out of options :( the stuff I tried above were the suggestions on the internet...
my google contacts and gmail are both syncing fine. only the calendar has a problem.
it keeps showing: sync is currently experiencing problems. it will be back shortly.
hope someone can help me! thank you
welcome to the forums!!!!!!!!
i moved you to the galaxy note forum where folks here who are more familiar with your phone might be able to help you better.
Hi jovijovijovi
I'm having the same problem as well. My Google Calendar and my Samsung Account would not sync. "Sync is currently experiencing problems. It will be back shortly".
Have been hitting the "Sync Now" for almost a day... Still won't sync.
Need help as well.
i had the same issue but then realized i had also downloaded the google calendar from the play store- tried it for a bit and then uninstalled going back to the stock calendar. that's when my syncing stopped. i reinstalled it and now stock calendar syncs and i just ignore the one from the play store. not sure if you did same but that was my issue.
I'm experiencing something similar, but I can create an appointment and sync FROM Google calendar TO my Note2 (it shows up on the note2 calendar). However, if I create an appointment on my Note2, it won't appear on my Google calendar. I'm going nuts trying to figure this out. Help, anyone???...
i had similar problem once and noticed my GS3 calendar was defaulting to Mycalendar when making appts and not my google calendar! perhaps that could be the issue???
When you are on your device and go to set an appointment it will give you the
option at the top to select what calendar to use, change it to your gmail account.
