It might of crashed in old version of unSENSEable. It works fine in current version
Weird I just flashed unSENSEable and it forces closes too :/. Could it be a app that's conflicting with it?
wow.. I am using it right now.. LOL on unSENSEable V2.0
are you trying to restore it or install it fresh?
try flashing the ROM and dont add any apps. add it straight from play store
I dont know pal. What hboot are you on??... What recovery.. ? Did you format all partitions(except SD card) then wipe dalvik cache before flashing..... A ton of peeps have flashed my ROM..... 2 or 3 experienced issues. Its also strange that you are having issues with Google keep. Those people also had issues with keep. All of them eventually got it worked out. Check the Thread. Maybe it could help you
.I bet you havent took the OTA updates yet ?
I would do that then get on jbear hboot 1.5 after you reroot
No I haven't done anything other than flashing ROMs ever since I rooted and s offed in September.
So I should do the RUU stuff get the OTAs and everything then get boot 1.5?
I dont wanna promise you that its gonna get your google keep going.....
But I always reccomend people do that If they already havent done so
. Seeing as how it looks like a time consuming process I'll do it later lol. I'll post back my results. I like your ROM by the way
.I'm not going to say it.So what's the difference between blurom and mobster hd with regards to what Google Keep expects to see?
ramjet73
OK, then.You don't have to say anything. Just type it![]()
OK, then.
Why don't you ask mobstergunz since he seems to know?
ramjet73
Thank You .. Its not that time consuming... The whole process should take a hr..and you will be up and running. you can flash the RUU thru bootloader. then take OTAS ,update profile/prl. Then flash recovery thru bootloader... Then Rom thru recovery... And hboot thru bootloader...I have the files if you need them.. just pm me
