Help Google Voice voicemail notifications...help!!
WizeGuyDezignz
Android Expert
I am currently using Google Voice for my Visual Voicemail. When someone leaves a voicemail, I get about 5 notification sounds in a row! It's so annoying. I bascially get a couple of email notifications, a message notification, etc.
Is there a way where it only makes one notification sound and just shows that you have a new voicemail? I don't need a bunch of things going off at once. Any help would be appreciated, thanks!
If you are using the GV app, you need to go into your GV account and turn off all notifications.
If you don't want to use the app, you can apply the advise in reverse ;)
Go to your google voice page and go to settings and go under Voicemail and SMS. Uncheck "email message to:..." and "Send SMS to" and get rid of Forward SMS to my email.
Cool thanks! If I do what you suggested will my phone at least play a sound and notify me that I have a new voicemail? I just want one notification instead of SMS, Email and all that. Thanks!
Google voice itself has options for SMS and email notifications (which can be turned on or off). If you turn these both off it shouldn't do anyhting when a VM is received.
I would think the app has an option within its settings to send a notification (notification bar/LED/sound etc). I do not use it, so I am not 100%.
Key is to turn everything off except for one.
Yeah ditch the sms and email notifications and use only the notification in the GV app on your phone. You can set to audibly alert there plus leave a message in the notification bar so when u click on it, the app will launch and u can read/listen to your mail.
