I'm getting this error when I try to deodex framework-Res.apk,
* Starting framework.odex************************************************THIS WILL TAKE A LIL BIT!!********* Deodexing... * * * * * * * * * * * * **Error while disassembling method Lcom/broadcom/bt/service/map/provider/mms/MmsProvider;->parseBodyParts(Lorg/apache/james/mime4j/message/Entity;Ljava/lang/StringBuffer;Ljava/lang/StringBuffer;Ljava/util/ArrayList
V. Continuing.org.jf.dexlib.Code.Analysis.ValidationException: class Lorg/apache/james/mime4j/message/Entity; cannot be resolved.* * * * at org.jf.dexlib.Code.Analysis.ClassPath$UnresolvedClassDef.unresolvedValidationException(ClassPath.java:535)* * * * at org.jf.dexlib.Code.Analysis.ClassPath$UnresolvedClassDef.getClassDepth(ClassPath.java:543)* * * * at org.jf.dexlib.Code.Analysis.ClassPath.getCommonSuperclass(ClassPath.java:383)* * * * at org.jf.dexlib.Code.Analysis.RegisterType.merge(RegisterType.java:275)
* * * * at org.jf.dexlib.Code.Analysis.AnalyzedInstruction.mergeRegister(AnalyzedInstruction.java:185)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.propagateRegisterToSuccessors(MethodAnalyzer.java:444)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.setPostRegisterTypeAndPropagateChanges(MethodAnalyzer.java:424)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.setDestinationRegisterTypeAndPropagateChanges(MethodAnalyzer.java:396)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.analyzeCheckCast(MethodAnalyzer.java:1837)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.analyzeInstruction(MethodAnalyzer.java:682)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.analyze(MethodAnalyzer.java:208)* * * * at org.jf.baksmali.Adaptors.MethodDefinition.addAnalyzedInstructionMethodItems(MethodDefinition.java:370)* * * * at org.jf.baksmali.Adaptors.MethodDefinition.getMethodItems(MethodDefinition.java:292)* * * * at org.jf.baksmali.Adaptors.MethodDefinition.writeTo(MethodDefinition.java:132)* * * * at org.jf.baksmali.Adaptors.ClassDefinition.writeMethods(ClassDefinition.java:323)* * * * at org.jf.baksmali.Adaptors.ClassDefinition.writeDirectMethods(ClassDefinition.java:292)* * * * at org.jf.baksmali.Adaptors.ClassDefinition.writeTo(ClassDefinition.java:136)* * * * at org.jf.baksmali.baksmali.disassembleDexFile(baksmali.java:201)* * * * at org.jf.baksmali.main.main(main.java:282)opcode: check-castCodeAddress: 100Method: Lcom/broadcom/bt/service/map/provider/mms/MmsProvider;->parseBodyParts(Lorg/apache/james/mime4j/message/Entity;Ljava/lang/StringBuffer;Ljava/lang/StringBuffer;Ljava/util/ArrayList
V
Error while disassembling method Lcom/broadcom/bt/service/map/provider/mms/MmsProvider;->onPushMsg(ILjava/lang/String;BBBLjava/lang/String;Ljava/lang/String;Ljava/lang/String
V. Continuing.org.jf.dexlib.Code.Analysis.ValidationException: class Lorg/apache/james/mime4j/field/UnstructuredField; cannot be resolved.* * * * at org.jf.dexlib.Code.Analysis.ClassPath$UnresolvedClassDef.unresolvedValidationException(ClassPath.java:535)* * * * at org.jf.dexlib.Code.Analysis.ClassPath$UnresolvedClassDef.getClassDepth(ClassPath.java:543)* * * * at org.jf.dexlib.Code.Analysis.ClassPath.getCommonSuperclass(ClassPath.java:384)* * * * at org.jf.dexlib.Code.Analysis.RegisterType.merge(RegisterType.java:275)
* * * * at org.jf.dexlib.Code.Analysis.AnalyzedInstruction.mergeRegister(AnalyzedInstruction.java:185)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.propagateRegisterToSuccessors(MethodAnalyzer.java:444)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.setPostRegisterTypeAndPropagateChanges(MethodAnalyzer.java:424)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.setDestinationRegisterTypeAndPropagateChanges(MethodAnalyzer.java:396)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.analyzeMoveResult(MethodAnalyzer.java:1623)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.analyzeInstruction(MethodAnalyzer.java:647)* * * * at org.jf.dexlib.Code.Analysis.MethodAnalyzer.analyze(MethodAnalyzer.java:208)* * * * at org.jf.baksmali.Adaptors.MethodDefinition.addAnalyzedInstructionMethodItems(MethodDefinition.java:370)* * * * at org.jf.baksmali.Adaptors.MethodDefinition.getMethodItems(MethodDefinition.java:292)* * * * at org.jf.baksmali.Adaptors.MethodDefinition.writeTo(MethodDefinition.java:132)* * * * at org.jf.baksmali.Adaptors.ClassDefinition.writeMethods(ClassDefinition.java:323)* * * * at org.jf.baksmali.Adaptors.ClassDefinition.writeVirtualMethods(ClassDefinition.java:308)* * * * at org.jf.baksmali.Adaptors.ClassDefinition.writeTo(ClassDefinition.java:137)* * * * at org.jf.baksmali.baksmali.disassembleDexFile(baksmali.java:201)* * * * at org.jf.baksmali.main.main(main.java:282)opcode: move-result-objectCodeAddress: 482Method: Lcom/broadcom/bt/service/map/provider/mms/MmsProvider;->onPushMsg(ILjava/lang/String;BBBLjava/lang/String;Ljava/lang/String;Ljava/lang/String
V
Press any key to continue . . .
