parkerskouson
idk what the heck happened. i just flash ics for fun and it totally worked!!!!!!! im so happy. ok now...... do i have to be on stock rom to activate it????? if not, i need help rootin 6.16......
thanks
parker
thanks
parker
, but not sure what you mean by error in the ruu. you get this while downloading it? this ruu you do not run. you just put the file on the card and boot into hboot and hboot will scan for the file and ask to update if it finds it.
