I recently upgraded to an HTC desire Z from a Nokia N97 Mini. I'm very happy to have done so as the N97 Mini is a useless pile of c**p!
Anyhoo... One of the niggles that I have is the GPS. If I use it, it works fine and gets a fix in seconds.... But if I try to use it again a bit later on, I cannot get a fix, even though I did before in the same location.
If I turn the phone of and on again or do a restart, all is OK.
I use GPS quite a bit for navigation and general location based applications.
This has become quite a problem. It doesn't happen all the time, but when it does it's when I really need a quick fix... When testing, and if time is not an issue, all is OK... it's as though the phone knows I need it to work properly and is playing with me
It doesn't matter what GPS using app I use. Back in the early days of GPS on phones, certain apps kept hold of the GPS and others could not use it if the app was not shut down properly (My N95 8GB was good at this)... Could the same be happening here?
Is there a quick way to shut down apps, or to check if any apps are running?
Thanks In Advance.
Thanks In Advance.
