GPS location not working after Factory reset
jkmailley
So I did the factory reset and reinstalled all my apps...everything working fine so far. Previous glitches have not resurfaced. However, LOL, now Beautiful widget/HTC clock-weather is acting up. It keeps saying my GPS location is Vilnius....I'm no where near Lithuania.
I've updated the progaming &roaming twice and toggled geo location multiple times...
Don't know what to tell you. Mine takes between 3 and 5 minutes usually to lock on to my position, sometimes longer.
This not using maps or anything like that...this is the Clock/Weather. It is happening with both Beautiful Widget and HTC widget. My cell still says my location is Vilnius, Lithuania. How did I get back to NJ!?
The HTC app does NOT use GPS. I have to presume the Beautiful Widget doesn't either.
Have you done *228, option 1 or 2 yet ?
In the HTC clock/weather widget, tap on the clock, then at the bottom of the screen go to the globe(add city) and delete the ones showing except current. Also tap the temperature, then click the +, and do the same thing.
I've done all the above. I only have current location listed. It keeps flipping now for the last 10 minutes between my hometown and Lithuania. Could this be my phone or VZW?
LOL...I was sitting on my couch watching TV.
Before I went to bed, I turned my GPS location onto street level and left it as "Current Location". I plugged it into to charge as well overnight. I woke up and I was still in Lithuania. I unplugged it from charging, set my location to the closest mega city (NYC), and turned it off for 5 minutes. I then turned it back and removed NYC and left it only as current city. It found my hometown. I drove to work and it says my work location. It's seems to be fixed now. I'll let you know if I start globetrotting again.
