Help GPS Problems
MonkeyDot
Hi, I created this thread after looking around for a solution for 2 hours.
My GPS basically isn't working. The icon in the notification bar is empty, not blinking or full. When I pull it down it says searching for GPS signal, but never ends.
This happens in every app using gps.
I have v4.2.2
It's also not a hardware issue, some time ago (maybe before I updated to 4.2.1, it was working)
Help? This is really really frustrating me.
I have had it happen before. Required several reboots before it started working again. I may have had to do a factory reset. Hasn't happened since.
Not sure if you are rooted but have you tried rolling back to an earlier rom like 4.1 or a custom rom to see if it works?
