Help Gps won't lock in DL30
exzacklyright
It was never very fast on Dl09 but in DL30 I can't even get it to work. I tried the gps status app as well and no luck :/
which radio are you using? I am running dl30 with dj09 and my gps is searching, searching, searching, searching .... horrible! I may reflash the radio
Another vote for DJ05. Though I will say it was hit or miss until I did a proper wipe with jt's updated recovery.
I had this problem on Saturday. I have DL09 installed and I couldn't get my GPS to lock at all on the way to my destination. I had to turn on Google and VZW location services and then my GPS locked inside 10 seconds. I turned everything off, rebooted, turned on just GPS and nothing. Turned on Google and VZW locations services again, and boom GPS lock. Perhaps that has something to do with it?
Im' on the DL09 radio right now too... maybe i'll try the DL05. I have the verizon / google services on but still won't lock even after 10min.
Yeah give it a try Im still on DJ05 radio although I have tried the DL09, same difference IMO
This is the biggest POS I've ever owned! I just got back from a quick road trip and the GPS won't lock on unless I pull the battery out ... it will lock on in a milisecond on reboot but I should NOT have to pop out the battery to get the $#@&! GPS to work. Yes, I'm frustrated! :mad:
installed DJ05 and still nothing :[
"searching for GPS" .... 15 minutes and counting. This is ridiculous. I don't know what else to do. I've tried dj05 and back to dl09 ... still "searching for gps" ...
lol well it's either a bad radio or bad hardware. someone in IRC mentioned the 1 yr warranty and that you could get it replaced. I dunno what I'm gonna do.
here's a comment from xda...
Basically it needs to be turned on from settings for the 1st time after a reboot...then the pulldown will be instant. To test this, reboot phone with gps off, when it boots turn gps on from the pulldown...it wont lock...go to settings and turn it off then on...it will lock instantly. Like i said, it seems to need to be turned on through settings initially, then it works instantly any way you use it...hope i helped.
lemme know how it goes... that didn't work for me either so who knows
Ok the VZW rep told me you have to stand on one leg, hop around in a circle while touching your elbow to your ear and humming the verizon start-up tone .... then it should lock on quickly :rolleyes:
I may be onto something here .... are you using Google Nav? If so are you trying to GPS "recent destinations"? I have .... it won't find your recent destinations but when I spoke "walmart" it locked right on .. indoors. Have I mentioned that I hate this phone?
UPDATE: ok now that I've "spoke" the initial destination it will now find my "recent destinations" ... what a hassle
yeah i was just trying using gps status, and google maps
