hello guys, is it possible to use my phone as a GPS without internet connection or data plan? i coudnt get any signal it always says waiting for driving location forever!![]()
Without data or Wi-Fi there is no Assisted GPS and therefore a lock will take around 20-30 min's and be less accurate.
what is the best thing i need to do? i dont have any data plan. the gps on the upper right side seems to get locked stop blinking, and the phone always says getting driving directions forever the circle is always loading. huhuhu. and then it says data connection lost.
Are you trying to use it for driving navigation without AGPS?
sorry, but i dont know what is AGPS. my phone is not rooted, im just trying to use my GPS for the first time, and im using the gps that comes with the phone.im on ICS 4.0.3 now. can you tell me on how to use gps or any settings that i need to look? i appreciate for the help sir.
If you have no data plan or access to Wi-Fi then I am afraid that Maps will not work as you will be unable to download the map data for your location.
but before updating from 2.3.4 to 4.0.3 i can still use my gps with no problem. but after ics i cant use it no more! huhu
How were you downloading the map information without a data connection?
when i was home i have wifi, that is how i download the map, but when i go out, and i want to use my gps i cant use it no more. i guess the gps on this phone with out data plan is so useless.
if you download the map to use locally (on your sd card, etc.), then wouldn't Google maps and the GPS work, without a data plan or wifi?
