Help Gps wont work!
VLADIMIRTM
Member
i try everything i can to make it work but i cant make it work,please help,its always searching for GPS and never found it! thanks
Have you tried toggling into Airplane Mode on and then off? I've never had a problem getting GPS lock in just a few seconds until recently and found threads that mentioned toggling into Airplane Mode and then back out. I've done that 2 or 3 times in the past couple of weeks and after doing it, I've been able to get a GPS lock.
Hi, I have the exact same problem. No amount of toggling airplane mode or battery pulls will fix the issue. Does anyone else have some other suggestions?
From the Android Market, install Mike Lockwood's GPSTEST.
Then go to some spot with lots of open sky and start the test. See if you can detect any satellites. If you can't, remove the battery cover from your phone and try again. Are you able to pickup any satellites with the cover off?
