Mine is working now but it does take a while to get a fix, more than 10 seconds.
sam! that guy's awesome. I feel like i know the GSII already![]()
thats cos it uses the cell towers to figure out where you are roughly then uses the gps to figure it out down to the inchJust tested......using GPS Status
With data connections disabled (via APNDroid) then...
After a few seconds it showed 4 - 9 satellites but even after a minute there was never a fix.
Turned off GPS, turned on data connections again, then...
After 5 - 6 seconds I had 6 fixed satellites
thats cos it uses the cell towers to figure out where you are roughly then uses the gps to figure it out down to the inch![]()
so does this mean his gps isnt working as it should?
So I've hopefully getting the GSII but I just wanted to know what my chances are of getting a dodgey GPS. I mean I don't mind if it takes a little long, but I use GPS sometimes and I would at least like it to be functional.
SO please answer the poll.![]()
