R4WK1LL
Hi guys, currently my phone is stuck on boot loop (after HTC logo, it'll keep restarting without going into boot animation), but I can flashing stuff without any issue (with unlocked bootloader, S-OFF and Super CID). I've tried some things: flashed some RUUs, installed custom recovery (CWM / TWRP / 4EXT), but in the end when rebooting the phone after successfully flashing RUU or trying to get into the recovery --> another boot loop.
When I check the vars, the baseband value is null, even after flashing RUU (then reboot). If I manually flashed Radio/Firmware (ex: 11.25.3504.06_M), or boot.img from my current ROM, then check the baseband right away, it'll show the version number correctly; but after rebooting the device (which goes into boot loop again), then I check the baseband, it'll be empty again, so it seems like it just won't stick, which is probably the culprit.
Some infos:
Any ideas on what should I try next?
Some infos:
Code:
version: 0.5
version-bootloader: 1.53.0007
version-baseband: N/A (after every reboot)
version-cpld: None
version-microp: None
version-main: 1.20.401.8
serialno: ~snip~
imei: ~snip~
product: shooter_u
platform: HBOOT-8260
modelid: PG8630000
cidnum: 11111111
battery-status: good
battery-voltage: 5719mV
partition-layout: Generic
security: off
build-mode: SHIP
boot-mode: RUU
commitno-bootloader: 10e127f0
hbootpreupdate: 11
gencheckpt: 0
