Talderon
Android Expert
Hope this all makes sense, please ask questions here, not via PM.
Things you need to know about trying different OS's on your HD2.
I am putting this comprehensive guilde to help those that want to try other OS's and know they can go back to any OS without issue.
If there are any questions, please post them in this thread so others that might have a similar question/issue can benefit from the responses.
Sources: Various people from XDA and my own personal experiances.
Android:
First things first, what are the build types and what are the differences?
SD Builds: These were the first types of Android ROM's where the operating system is booted and loaded from the SD Card in to the devices RAM and run from there. This requires you to dual boot. You boot into Windows Mobile and then launch the Android boot from there. The data.img file determines now much "internal" storage you have for applications. This is updated on a regular interval so when you reboot your device, it is current.
NAND: The space where ROM's are flashed and loaded from is called the NAND space. Rather than having to boot into 2 operating systems as the SD version, you totally wipe Windows Mobile from your device and flash the ROM onto the device and boot straight into it. This makes your device more like a true Android device than other ways to boot.
Things you need to know/do.
1. Backup all your important data/settings
2. Decide if you want to run SD or NAND
-- Note: Many Dev's are not supporting SD anymore, but there are still some great Dev's working on SD builds for you to try
3. Read read read. Most importantly, READ THROUGH ANY IMSTALL INSTRUCTIONS BEFORE YOU FLASH/INSTALL ANYTHING!!!
4. If you are going to go NAND, decide if you want DAF or Clockwork.
-- DAF: This flashes the ROM directly from MAGLDR to NAND. Limited functionality on backups, upgrades (without wipes) and installing .zip mods
-- CWM (ClockworkMod): Becoming more of the standard as it gives you functionality from the Full Android Recoveries and other utilities.
THESE STEPS ARE NEEDED FOR ALL (SD OR NAND) ROM'S!!!!
First things first, you have to flash HSPL onto your device to unlock the bootloader for custom flashing.
REQUIREMENTS BEFORE STARTING!! IMPORTANT, PLEASE READ THIS!!
1. YOU NEED A RADIO WHICH SUPPORTS 576 RAM (2.08.50 or later should be fine but the Radio NEEDS to be 2.**.50.**). I recommed the 2.15.50.14 Radio: Multiupload.com - upload your files to multiple file hosting sites! I have had no issues with ANY ROM with this radio
2. YOU NEED HARDSPL 2.08 INSTALLED ON YOUR DEVICE TO FLASH MAGLDR (steps below)
3. Download MAGLDR 1.13 package and extract to an empty folder on your pc: xda-developers
FLASH HARDSPL (REQUIRED!! DO THIS BEFORE ANYTHING ELSE)
The Original HardSPL Thread: [HSPL/HSPL2] HowTo flash everything
- xda-developers
NOTE: If you have Vista or Windows 7, update WMDC to v6.1 first: Download details: Microsoft Windows Mobile Device Center 6.1 for Windows Vista (32-bit)
NOTE: Turn OFF any AntiVirus Program first as it WILL interefere with the flash (there is NO harmful code in the program)
Note: HardSPL CANNOT be installed via microSD Card.
IMPORTANT: To install/uninstall this HSPL3 there must be any SPL version from this list on your device:
SPL 1.42.0000, SPL 1.62.0000, SPL 1.66.0000, SPL 2.07.0000, SPL 2.08.0000, SPL 2.10.000
To Uninstall you can flash a Stock ROM via SD card or use HSPL3 application (You need select 2.08.0000 in the choose screen)
1. Download HardSPL package and extract to an empty folder: xda-developers
2. Synch Phone with PC in Windows Mobile!!! It has to be connected to activesync or WMDC via USB cable
3. Run HSPL3_PKG.exe from your pc and read all the text carefully
4. When finished reading click next in the HardSPL program
5. The program will now check the usb connection and enter bootloader screen (tri colour)
*You can select between SPL2.08.0000 or 2.08.HSPL. This is to avoid people with 1024LEO's installing an incompatable version and bricking their device*
6. Select 2.08.HSPL for HardSPL and click NEXT.
7. Your choice will be flashed to your phone.
8. When its finished the HardSPL program will pop up a box saying "Successfully Done" and the phone will reboot.
9. Click ok to terminate program.
10. Congrats, you just flashed HardSPL.
*Go into BootLoader Mode (turn off phone, then press and hold the VOLUME DOWN then Press and hold the POWER button. After about 3 seconds the tri-coloured screen should appear). Verify the screen shows the SPL or HardSPL you installed*
To Remove HardSPL from your Device or Flash back a Stock Rom and Stock SPL for Warranty Purposes
You can remove the HSPL by flashing an original SPL from microSD card OR by running the HSPL3 application (You need select 2.08.0000 in the choose screen).
* You can also use the microSD Card method to flash back your Stock Rom and Stock SPL that you originally had on your phone*
- Download a shipped Rom: 4shared - Shipped Leo ROMs - shared folder - free file sharing and storage
- Rename the extension to .zip
- open it with winzip and extract the RUU_signed.nbh file to a folder
- Rename it to LEOIMG.nbh and copy it to the root of a microSD card thats been formatted to FAT32
- Insert your storage card into your phone
- Enter Bootloader and follow onscreen instructions to flash
FLASH RADIO
Flashing Via ActiveSync
1. Download your required Radio and rename the extracted file to RUU_Signed.nbh
2. Sync your phone with the PC
3. Run CustomRUU.exe from the Radio's Folder and follow the instructions (if one isnt included then download it from here: xda-developers)
Flashing via MicroSD Card
Use same method as Flashing a Rom via MicroSD Card
NAND BUILDS ONLY!!!!
FLASH MAGLDR TO YOUR DEVICE
The Original MAGLDR Thread by Cotulla is here: [DFT]MAGLDR 1.13 released! [AD RECOV support added] - xda-developers
NOTE1: LEO512 and LEO1024 are both supported
NOTE2: MAGLDR doesn't replace OSPL/HSPL. It runs in the chain after. So it's safe to install and remove it
NOTE3: You can flash between 1.11, 1.12 and 1.13 versions on Magldr without losing your NAND Rom
1. Synch Phone with PC in Windows Mobile!!! It has to be connected to activesync or WMDC via USB cable
NOTE: As an alternative method to activesync you can restart your phone in Bootloader Mode, then connect the usb cable and wait until 'usb' appears in the bottom half of your phones screen
2. Browse to the folder you extracted your Magldr Package files to on your pc, right click on ROMUpdateUtility.exe and select Run as Administrator
3. Tick the box to confirm you are aware of the risks and select 'Next'
4. Tick the box to confirm you have followed the preperation steps and select 'Next'
* The program will now check the usb connection *
5. Select 'Update'
6. Verify the image you will flash (it should say 2.00.000.0) and Select 'Next'
7. Read the process list and Select 'Next'
8. Your phone will enter BootLoader Mode and the progress will goto 100%
9. Your phone will now Reboot. Congrats, you just flashed MAGLDR.
NOTE: To Enter MAGLDR Menu Screen after installation, Long Hold the Power Button when resetting the phone and the menu will appear
FLASH YOUR ANDROID ROM
NOTE1: This section is only applicable AFTER you have flashed MAGLDR to your Device
NOTE2: Make sure your phone is still connected via usb cable before starting
* When your phone Reboots it will Enter the MAGLDR Boot Menu Screen *
1. Press the 'Volume Down' button to goto Option 5: USB Flasher and press the 'Call' button (far left of the 5 hardware buttons at the bottom)
2. The menu will enter Android Flasher mode and install usb drivers if not present
3. Browse to the folder you extracted your NAND Android Package files to on your pc, right click on Run DAF.exe (or Install.exe if DAF.exe isnt present) and select Run as Administrator
4. Read ALL the text and then select 'Next'
5. Read the information and select 'Next'
6. The installer will now detect USB and then flash your Android Rom to NAND
* You can follow this progress on your Phones Screen *
7. When flashing is complete your phone will Reboot and proceed to boot Android from NAND
FLASHING A NEW NAND ANDROID ROM OVER A PREVIOUS ONE
Once you have flashed Magldr to your device you do not have to go through the whole process again if you want to flash a new NAND Android Rom:
1. Turn your phone off
2. Restart your phone by holding down the 'Power' button and keep holding it down until the Magldr Menu appears
3. Press the 'Volume Down' button to goto Option 5: USB Flasher and press the 'Call' button (far left of the 5 hardware buttons at the bottom)
4. Browse to the folder you extracted your NAND Android Rom files to on your pc, right click on Run DAF.exe (or install.exe if Daf.exe isnt listed) and select Run as Administrator (if using Windows Vista or Windows 7)
5. Read ALL the text and then select 'Next'
6. Read the information and select 'Next'
7. The installer will now detect USB and then flash your Android Rom to NAND
8. When flashing is complete your phone will Reboot and proceed to boot Android from NAND
UNINSTALLING MAGLDR AND NAND ANDROID (FLASHING WINMO BACK TO NAND)
To uninstall Magldr and any Android Rom that you installed to NAND, do the following:
1. Download a Stock Rom from: [ROM][OFFICIAL] All new official Leo 3.14 roms - also old 1.66/1.72 roms! - xda-developers or a Custom Rom from the HD2 Rom Development Forum (for LEO512 ONLY, LEO1024 users will have to use a TMOUS compatable Stock or Custom Rom that is LEO1024 compatable): HD2 Windows Mobile 6.5 ROM Development - xda-developers
2. Enter Bootloader Mode by taking the battery out, then put it back in and hold down the 'Volume Down' button while briefly pressing the power button.
3. After the phone enters the Bootloader Screen, plug in the usb cable so it says usb at the bottom of the screen
4. Run the Stock Roms .exe file (or run the customruu.exe file of the Custom Rom you want to flash)
* This will flash a Stock Rom and Radio while keeping your HardSPL untouched *
CLOCKWORKMOD RECOVERY
Download and details here: xda-developers - View Single Post - [01 FEB][RECOVERY] ClockworkMod Recovery for HD2 - v1.3
For MAGLDR NAND Boot;
1. Download recovery with partition size for the type of rom you plan on using, see guide below if unsure.
2. Extract downloaded file and load magldr into USB Flasher mode.
3. Run DAF.exe and follow instructions
4. After completed and phone reboots, hold power key and select AD Recovery from list
5. Recovery will now load
There is a 150MB, 250MB and 400MB versions available. The ROM you download will tell you what you need.
SD CARD ROM'S
(Installing Android)
Radio Version > Radio needs to be 2.08.50.xx or more (x.xx.51.xx are not compatible)
1) Micro SDHC card
Should be atleast 4 Gb, Class 2/4/6/8/10
Formatted clean with 32 or 64 Kb cluster size
2) Install automatic boot loader on WinMo :
This allows you to choose between booting into Windows or Android on start up. From 2nd Android bootup onwards these programs will make it easier to load Windows/Android at startup and you can even specify autoboot into Android if you wish.
Download this as a cab file and install in the phone memory (not in SD card)
Android Loader v6.0 Final for HD2: [APP] Android Loader v6.0 Final for HD2 - xda-developers
Exceller bootloader: [APP] Exceller Multiple Build Loader for Android/Ubuntu **Updated August 18** - xda-developers
You can of course manually always boot up Android anytime from Windows File Explorer by running CLRCAD and then HaRET files included in the Android build (see below).
3) Android Build :
Download your chosen Android build on your computer.
Extract / Unzip the folder on the computer
Now copy into the Root of your SD card.
Folder should be labelled "Android"
Once copied into SD card you will see 2 files: CLRCAD.exe and HaRET.exe which have to be run to boot into Android.
There will also be other folders / files (Android Apps, initrd.gz, system.ext2, rootfs.img, zimage, startup.txt, ts-calibration) please leave them as they are.
There are many choices in builds available, such as - MDJ, Darkstone, MIUI,. Please search the forum to look at the different features. I can't advise you on what clothes to buy. The same reasoning applies to advising on Android builds, you have to find out what is right for you...Try the build, if you dont like it, just go for another build..copy and paste your new android folder over the old one and its done.....
4) Data.img :
Your build may have a ready-made one included in the build folder or available to download separately. Size of data image is upto you, 256Mb/512Mb/1Gb (or more). This determines the Size of your Android operating system space for settings and downloaded apps etc. Bigger size allows you to keep more apps etc.
NOTE: I have found that any data.img file that is larger than 1GB can give you issues with downloading and installing apps from the market. You will mostly get errors about "not enough space". The only way to fix this is to wipe and use a smaller data.img or manually install the APK (this does not always work though).
>> At start up if you have a ready-made data.img file, booting up in Android is much faster (5-10 min). (You can choose the image size yourself with this option)
>> If you boot up without a ready-made data.img (Clean Install), then this is created by Android system at first bootup which takes longer (up to 30 min) Here the system will choose its own set default image size depending on startup commands in the build. Its not easy to change this size once its created (although it is possible)
5) First Android Boot
Once you have reached this step you are all set. It really is that simple!
These steps are performed with the phone booted in WinMo
Charge your phone to 100%. This ensures proper battery calibration.
In your File Explorer open the Android folder on the SD card
Run CLRCAD - Nothing seems to happens - This is normal. !!!
Run HARET - Small pop up window with grey progress bar appears with message HaRET LINUX BOOTING - You should then see some text lines in the top left corner of the screen and then a Splashscreen (blank screen with a HTC logo) Please be patient and allow time for the initial bootup.
If Android loads successfully, then (depending on your build )another Splashscreen will appear and then the Lockscreen for Android is launched.
Set up your phone for first use as per onscreen instructions and let all account finish syncing before doing anything else
Once you are up and running here are some of my own tips to maintain your system.
1) Always back up of your data.img file on to your pc/mac (weekly)
This is better done in WinMo. This will mean that you can always have a failsafe arrangement for troubleshooting.
2) Troubleshooting (If you start getting data corruption errors or force closes .
> Make another Clean Install of the build -Boot into Android- Reboot in WinMo - Connect to Computer - Copy backedup data.img file into the New (compatible) Android folder.
DONE! you are back where you started. All apps, settings, contacts,emails, messages are saved as they were at the time of backup.
You can also use a backup programme like Titanium Pro. This is useful when going over to a completely different chef build as you cannot (usually) take your old data.img file across.
3) Changing kernels
Follow instructions on the relevant thread.
For MDJ / Hastarin Kernels the following steps work
Boot up in windows - copy 'zimage' and 'Root' folder (which has modules) from the new kernel and paste into your /Android folder on SD card (i.e replace zimage of old kernel).-
Boot up android - check for successful upgrade under Settings>About phone>Software>Kernel ... the new kernel should be listed.
On boot up android will copy the contents of the /Android/Root folder to the relevant place.
If upgrade is successful then while in Android use a File explorer (with root permissions) to delete the 'Root' folder within Android folder, as this is no longer needed.
Note: Some kernels require the Modules (wifi,bt,lights etc) to be copied manually using Root File explorer while booted in Android. Please check the relevant posts for correct steps.
4) Upgrading Android Builds
I always do a clean install i.e let the Android build its own data.img with a clean formatted SD card.
Once this is done then copy your old backed up data.img and overwrite the newly created data.img to get all your info and settings as they were.
Caution: data.img is usually not compatible across different chef builds and its best to start a clean install if you are going to use a completely different build altogether. You can get you settings back by using a backup programme such as Titanium. Google sync will get your Contacts and Calendar back anyway if you have synced it previously to Gmail account.
5) Improving Battery Life
Having read through a lot of forums and trying out various techniques here are tips that have worked for me.
Charge your phone in WinMo to 100% (Green LED) While still connected to charger boot to Android and wait for the LED to go green. Then disconnect from charger.
Autoboot before launching into windows/sense fully, I use Exceller autoboot in 3 sec.
Rebooting Android 2-3 times after initial install and letting it 'settle' for a 1-2 days
Turn off any functions not required e.g BT, WiFi, GPS, Autosync
Turn down screen brightness to minimum
Use a battery current widget to monitor drain
Conditioning of battery: Boot into windows when battery is @ 5%, Discharge the battery fully and let the phone turn off> charge fully to green LED while phone off >> Boot up in Android and continue charging till LED green>> One cycle every 2 weeks
Recalibration: In Android with File explorer (e.g ES Explorer), Choose settings, enable root access and then in Root delete ... /data/system/batterystats.bin . This should be done when 100% charged, Now disable root access in file explorer and close, Run the battery down fully and follow the step above...
Fully conditioned battery should show about 4.2 - 4.3 V charge at 100% (Free app Battery Indicator)
Dataswitch (free app) allows switching mobile data when phone is not in use such as during night time etc
I keep Airplane mode in windows as default before first boot in Android (Not sure if this really helps)
For me greatest battery drain seems to be when i am in area of poor phone signal> switching to 2G helps using Dataswitch app
Things that don't work:
Task killers are not really very useful according to Hastarin
Android:
FLASH RADIO
5. Select 'Update'
SD CARD ROM'S
1) Micro SDHC card
3) Android Build :
4) Data.img :
3) Changing kernels
