Swainsmith82
Android Expert
I decided to start a new thread because I've been sifting through the threads here and it seems folks are still having trouble moving apps to sd. You can do this by simply adding two lines to the build prop. You'll have to go to settings/apps and move them from there. Some apps do not allow this, but just check each app installed and see which ones give you this option.
The two lines are..
ro.lge.capp_osp=true
ro.lge.capp_move_sdcard=true
Here's a screen shot of where to place them
https://db.tt/YoN8ULa9
UPDATE:
If you want to move more apps this is the only app I've found without partioning the sd to move.. It is a paid app but well worth it. The free version only allows five apps to be moved.
F2SD
https://play.google.com/store/apps/details?id=mobi.pruss.force2sd
The two lines are..
UPDATE:
F2SD
so yea try at your own risk!!!
