everything works great until i reboot after choosing to use the partition i made for internal memory. when i reboot i get stuck on koumakernel 2.5 logo. if i try to do a restore from backup i get stuck on samsung galaxy prevail logo. only way to get back up and running is to start over with odin. i would really like to use the sd partition for internal memory. any suggestions? thanks.
Hi,
did you read my post a little up the page ? Now you can try that and see if it helps. But sometimes, it's the SD-Card itself causing trouble ( may try a different one !! )
here is a "copy/paste" from my post above :
As I said, I had the same trouble before as you do... Not sure what the cause is, but it could be the SD-Card itself.... ( do you have a spare other one to try ? In my case, it was just this particular SD Card, all other, all sizes would work...)
Whenever I was stuck at the Kouma logo, I just re-installed CTMod again, booted the phone all the way up, rebooted into CWM recovery, installed the Koumamod1.7.apk via the APKInstaller, booted, back into CWM and formatted sd-ext, rebooted all the way up, went to the koumasettings, selected data, booted into CWM recovery and formatted the sd-ext, then a final reboot and it worked....... Have done this same procedure on 5 different SD-Cards and all work, except ONE, I never could get it to work.
My advise to try : Don't Odin the base band, that's fine, just reinstall CTMod368 from within CWM and follow the steps above ! My point is, have the sd-ext formatted, then change koumasettings to DATA, boot into CWM and format sd-ext again. See if that works.
Good luck, let us know if it helped !
Hello, I also used the guide successfully to root my samsung prevail. Great work by you guys, have couple of question though. One is the network is showing as Unknown where it used to show Boostmobile in the past, I think that is causing some issue with other apps i used and making it think like I am roaming.
Second I am also having some more dropped call issues after the update. Last I am wondering if there is anyway to install some of the boostmobile app back.
Thanks for your help in advance.
Hello, I am a newbe and a dummy. I just rooted my phone all is ok till i got stuck on the Kouma logo. This may be a stupid queston, could you please explain how I would go about installing the Kooumamod1.7.apk via the APKinstaller. I have that file on my pc but it is not on my phone. Do i put it in there in USB mode? I would appreciate any help you could give me. ThanksHi,
then reboot. And give it at least 10 min to boot all the way up.
you need to use a root explorer or titanium backup. the explorer, you go into the folders and delete them or titanium might be the easier route if not familiar with all the folders and stuff. just be careful to not delete anything of importance. make a cwm backup first incase so you can restore back if need be.i followed all the steps and it seems they worked. however i can't seem to delete the unwanted apps like telenav. any ideas?
