Lordvincent 90
Did you grab the drivers from this thread? I'm not sure why they aren't working
Well I figured it out, all set for a 3rd. Rooted Prevail!!!
I cant find the FF19 Rooted files with tar files for odin. The link on this site and every other doesnt have it.What was the problem?
Updating the su binary has been known to break root. That IMG should give you root. BUT if your goal is to debloat your system, then you should probably follow the guide in its entirety. Ctmod is designed to be the slimmest version of the stock rom possible. It even has added features such as notification toggles, quite a few speed optimizations and the ability to use a partition you create on your sdcard as the phones internal memory. Basically giving you as much internal storage for applications as you desire.
Ok, thanks! So should I just start over from the beginning and see if it works?
You should already have cwm recovery, so there is no real need to use Odin again. (but you can if you like) I would just start up where you left off.![]()
If you only have 9mb free then that's DEFINITELY the problem. The backup is going to be fairly large. probably 200-300mb...
If you partition your card, the partition will be exclusively reserved for apps and their data. It won't be available for music/pictures/movies/etc.
I actually need to update the guide as well. A backup made from the stock rom can't be restored with cwm. Cwm doesn't support rfs format (the stock rom is rfs) so that backup is kinda pointless (with the exception of getting you familiar with using cwm)
What version of CTMod are you runni9ng ???? If it is 3.75 or 3.75.2 than yes, there is an update. Current CTMod is 3.80.....
Make a backup, Put the .zip file onto the root of your SD Card, boot into Recovery and choose "Install ZIP from SD-Card !!
( You will need to re-download all your apps from the Play Store.... If you do a backup/restore with Titanium Backup, ONLY restore the apps, not the data !! )
Ok, like the title says, for dummies. I don't know how to make a backup,
Chapter two: Clockworkmod
ClockWorkMod v5.0.2.7 for Samsung Prevail SPH-M820
Now after all those minutes of work, we've got ourselves a phone that looks remarkably similar to what we had before. Only real difference is now there's a one-eyed android in our app drawer named Superuser. If we wanted to, we could stop here and delete the stupid stuff boost forced upon us. But we're not. We have yet to play with the other powerful tool in our toolbox, Clockworkmod. This recovery utility allows us to install roms and kernels, make backups, create partitions, all directly on the phone. And the best part is, we've already installed it!
In this section we will make a backup of the phone, repartition the SD card, and install a custom rom.
How to do a CWM Backup
Step zero: Go read the Clockworkmod thread listed above, and send some thanks their way.
Step one: Power off the phone, then hold the Volume Up and Power buttons to boot into recovery mode. You should see a blue text menu. Use your Volume up and down keys to scroll, camera button to select, and the back softkey to go back.
Step two: Select "Backup and Restore" and then select "Backup". Now leave the phone alone again for a few minutes and let it finish.
to restore the backup you go through the same process but choose restore instead and then select the backup of your choice. (The backup is named with the date and time it was created)
so I skipped that, I don't know what the root of my sd card is or how to move a zip file into it, so I skipped that.
root of sdcard means /sdcard/... as in on sdcard, but not in any folders. He suggested that because it would make it easy to find. However the method you used also works just fine
before I asked any more stupid questions, I wanted to see if there was anything I did understand, I decided to browse the Recovery menu, so I booted into recovery, chose install zip from sd card, then choose zip, and under goomanager, there was the update zip. so, being a dummie, I chose that and installed it and rebooted, hoping that I didn't need a backup. so now the update seems to be installed, but there is no boat browser. Is there a browser? I can't seem to find one. One of these days I am going to have to figure out how to make a backup and how to recover with it.
[B][SIZE="3"]Changelog:[/SIZE][/B]
[B]04/06/13 Version 3.80[/B]
Fixed SystemUI bugs (so it works with UOT)
Removed Voltage Control, Boat Browser, Stock Clock and the old Superuser
Added Lightning Browser, MiClock and CWM Superuser
Rebuilt CTSettings (fixed some bugs and added CPU/I/O Control to it)
Updated gapps
Updated File Explorer and QuickPic
Updated Busybox
Updated some of the theme
Updated the lockscreen a little
Updated font
Enabled CRT effect
New Settings layout
New boot and shutdown animation
Ported swipe to clear for notifications
Ported DSPManager from CM7
Ported animations from JB 4.2.2
Cleaned build.prop and init scripts
Performance and stability improvements
