Rastaman-FB
Extreme Android User
Long title i know but this needs to be done as all guides refer to clockwork and a few questions are asked but not answered with regards to whether this is possible with AmonRA and or a custom Alpharev hboot setup.
YES IT IS
1st things 1st, you must have S-OFF from Alpharev AlphaRev 1.8 1.8 is the latest and i would recommend flashing to this is you are on 1.5 or below
I was on N1table but it should work with all (other than oxygen)
Use "quick system info" from the market to determine your minimum layout requirements
Get the needed files from here [DEV][S-OFF] Custom MTD Partitions (resize data, system, and cache) - xda-developers and place them into a folder of choice on the SDCARD (i made one called "00CustomMTD" so it appeared at the top of the list
Create a file on the root of the SDCard called "mtdpartmap.txt" in the txt files put the values of the layout you are wanting to create (in my example i put "140 25" which is 140 system and 25 cache) - do not use quotes
once you have the files in place boot to recovery and make a nandroid backup with ext (remember this is amonRA 2.0.x)
Power down the device and boot back to hboot then select fastboot, connect device and use the following commands:
select recovery then go to "flash zip from sdcard" navigate to your folder and choose "bravo-recovery-v1.5.3-CustomMTD.zip"
once complete you will need to reboot recovery, you cannot do this in amonRA so open command prompt on pc and use :
once rebooted go back to backup/restore and restore your backup but do not reboot
once you have restored go back to "flash zip from sdcard" navigate to your folder and choose "bravo-boot-v1.5.3-CustomMTD.zip"
once done "reboot system now" and you will have your new custom layout
note: use system info to see your new layout
YES IT IS
Code:
fastboot erase system
fastboot erase data
fastboot erase cache
Code:
adb shell reboot recovery
