NeoSabin
Deodexing is the process of recombining .odex files to an apk and making it a complete package again, mainly for themeing. This is really for those of you out there that want to stay on stock and theme it.
As a shortcut i have uploaded the deodex and zipaligned files for those who want to save time. If so skip to step 4.
Deodexed files
PLEASE DO A BACKUP IN RECOVERY BEFORE PROCEEDING
1.The user friendly way to deodex your system apps is by using xUltimate
2.After downloading it run main.exe and choose option 5. This will copy your system apps to your PC and deodex them. The originals will be in the folders "origi_app" and "origi_frame". The deodexed files will be in "done_app" and "done_frame".
3.For optimization run zipalign on the "done_app" folder by starting zipaling.exe, choosing the folder then running the zipalign.bat that was created.
4.Copy the "done_app" and "done_frame" onto your internal sd.
5.After copying, set your phone to internet connection on USB and make sure USB debugging is on. Now run these commands in cmd.
adb shell
su
stop
mount -o rw,remount -t ext4 /dev/block/mmcblk0p12 /system
cp /sdcard/done_app/* /system/app/
cp /sdcard/done_frame/* /system/framework/
rm /system/app/*.odex
rm /system/framework/*.odex
mount -o ro,remount -t ext4 /dev/block/mmcblk0p12 /system
reboot
7.Delete the "done_app" and "done_frame" folders of you like.
6.Done. Enjoy your deodexed phone and the themes being provided by this great community
L
Base source used for this guide: [HOW-TO] Manually deodex your phone - RootzWiki
Deodexed files
adb shell
su
stop
reboot
L
