Help [guide][exp]How To Port GB from SDK
samrox144
Android Expert
hi @all
this method has not been tested but by this method i was sucessfull in porting HTC SENSE 2.1
and please dont quote entire post
req=
>android kithcen
>android 2,3 sdk system.img
>basic cmd skills
method
1=first copy the system.img from C:\android-sdk-windows\platforms\android-10\images
to original update folder in sygwin
2=now copy boot.img from your nanadroid backup or rom to same folder
3=now use kitchen to setup a working folder
4=in advanced menu selsect porting tools and selsect w to open boot.img
5=in boot.img folder open ramdisk and look for init.rc file of size <20kb of size open it and delete the line bootclasspath
replace it with this one
export BOOTCLASSPATH /system/framework/core.jar:/system/framework/bouncycastle.jar:/system/framework/ext.jar:/system/framework/framework.jar:/system/framework/android.policy.jar:/system/framework/services.jar:/system/framework/core-junit.jar
and save
6=now in ramdisk folder open default.prop
and change it to below lines
ro.secure=0
ro.allow.mock.location=0
ro.debuggable=1
persist.service.adb.enable=1
7=now build boot.img
8=now hit 99 and a zip file will be created in output
copy to sd card
reboot recovery
wipe data and format system
flash this in your phone
9=reboot
if it boots up you will have gb ...but gsm and everything else wont work but can be fixed only if it boots up
FAQ
1=IT ISNT BOOTING
A=copy the attached ramdisk and replace the one in boot.img by openeing it and build it then build the rom again and flash
2=why dont i do this and upload it
A.i dont have device test it
3=why dont compile from source
A.varun is working on it
even i want to do it but i dont have enough hard disk space to install ubuntu and start compiling
@all
if you have a extra HD of size 50gb or 100gb please pm me
link to ramdisk=
http://www.multiupload.com/RVZZGCOXNH
will try after making a custom 2.2 rom for a70 & can we port any other phone's froyo rom to it coz i have mi 300 .... having lots of froyo roms.......
@Sam
Everything is ready, including repo sync.
Source is of 2.73GB.
My speed is of 15Kbps, i m ready to keep it for weeks but the super issue is power supply.
Everyday 1 and 1/2 hours of loadsheding is there and my UPS lasts hardly half hour.
What to do?????????
I am really frustrated by these MSEB electricity suppliers?
any way to do it quickly except increasing bandwidth which i m not getting frm any of my frnd.:(:(:(
Don't worry it won't take weeks and keep it after load shedding so that power doesn't go again but due to your low speed there maybe failure of download of src
It is but Google servers are very powerful and at night they may give you some good speeds... or why don't you use a 3g trick so that you get atleast 200lb speed
Why is that I'm Tata I get 1mbs do this just activate a 3g plan of 11 rs and see keep balance below 9rs when you activate 3g plan
can u mention the tata docomo trick(sorry we r moving off the subject pls reply in the sticky thread provided by insane_subro )
@Sam
What to do?????????
I'm using a 800 VA UPS for my entire home (only lights and fan, no power plug) with a 100 AH tubular battery. so power cuts are not affecting me as long as they are within 10 hours.
but i know it is not possible in 24hours i.e downloading 2.73gb in 24 hrs at 15kbps...its impossible
u can give me links to that,I will download n make rar files of 100mb or 300mb whatever u prefer n upload it to my mediafire account.then u can download it easily.no worry of powercuts too.but I will b able to do this on Monday only.
Thanks for ur help mastermind but it has no links and has to be downloaded from Ubuntu itself.
do u have 50GB space??
then why don't u start building gingerbread.
We all are here to help you.
yes you are right, everything is using terminal only
I don't have 50gb in my hdd but I have portable hdd of 1 tb..is this ok?
i will clear this you dont need 50gb space 30gb is enough and that is you make only one build and should have atleast 3ghz cpu speed
you have a portable hdd why dont you move everything to that and repartition your system
and last for gb you need a 64bit pc if you have 32bit then use it in virtual box then you can compile even ICS in 32bit
Hmmm...my lappy capable of 64bit system but i m using 32bit but cpu is intel pentium dual core 1.60ghz...i think i will have to wait for my new lappy coming this feb(i5) but it's a long wait then.
with 1.6ghz your compile will take atleast 8hours and with i5 processor it will take 45minutes
and virtual box is best if it is a 32bit system
