Why wubi.
You'll get the full performance
OF Linux with it's own filesystem. Ext2, 3 or 4.
That's why sd-ext works , they've selected native over yaffs.
Swap?Repartition with windows 7 disk manger. C: itself & claim space. Linux will sit in extended partition.
I know but the hard disk has limitation of maximum 4 partitions.
1-> Windows 7
2-> Snow Leopard
3-> Dell Recovery
4-> Extra stuff
So, nothing left for ubuntu
About trying, I was referring to tutorial.
Did you try the tutorial?
Also, check my new thread, need some help
You need to create an Extended Partition.
You can partition that extended partition in as many small partitions as you like
@adityadeva
i can clearly see it ...the one named init.rc use that
you could have opened it and check you would have got it....
my sense port
ImageShack(TM) slideshow
I will port it to cm7 also as soon as cm 7 or kernel source is released
Connect the phone to pc during boot and in platform tools start ddms it will give you log cat...
My pc crashed because of too many process running in background I was playing call of duty 4 and also building a Rom plus browsing.. and some music in background all at same time...
Now it is fixed and no problems
I tried for logcat but it just hung upon waiting for device.Did you get the logcat black screen is good now try replacing libs as given in porting guide under all things root sub forum of a70
Black screen is nothing but no bootanimationand boot loops if still it won't work I will give a new way.. which has to work
yes remake it with my and did the logcat worked...you dont have to remove battery
use adb in pc and type
adb shell
su
shutdown or reboot
and dont use the ramdisk
adb shell
su
shutdown or reboot
