varun.chitre15
Android Expert
take my CPU
AMD Phenom X4 @4.2Ghz
4GB Ram DDR3
lol......
4GB Ram DDR3
lol......
Thanks for ur help mastermind but it has no links and has to be downloaded from Ubuntu itself.
He is not downloading ubuntu builds.he is downloading something which has to be downloaded via terminal using a repository. That can't be done using torrent.
I can help, I have 60kbps d/l speed.
And enough HDD space with ubuntu installed![]()
Yep, I'll but how much space I need?
I can download that in a day![]()
@adityadeva
i can clearly see it ...the one named init.rc use that
you could have opened it and check you would have got it....
my sense port
http://img705.imageshack.us/slideshow/webplayer.php?id=device20111207155106.png
i have used cm7 kernel to make it boot as stock was a useless and even you can port but app2sd is very important to make it boot
cm7 kernel power is limitless
Thank you cyanogen mod
I've built the GB as per Sam's tut. The#1 post.
But I am off to work. Yes it's Sunday, but I have to.
Will take some time to check whether gb boots or not.
Im 10000x exicited !! everything from now relies on sam & adityadeva & varun.........
Ok.
We are waiting.
Anyone tried this???
If not, should I?
Expanding wubi disk to 30GB.
