ShinySide
Extreme Android User
Animated status bar pulldown for GB roms
First off this should work with all GB based roms that use systemui.apk
there may be subtle differences but the basics should be the same all around.
and it's so simple that you'll love how fast you can integrate this into ROM's / themes / whatever your heart desires
1. take your systemui.apk and decompile it
2. navigate to layout folder
3. grab "status_bar_tracking.xml" and open it up in your editor
(now for the fun)
4. to the first line - "com.android.systemui.statusbar.TrackingView" add this ""android:background="@drawable/nameofyourxml""
<com.android.systemui.statusbar.TrackingView android:background="@drawable/nameofyourxml>
5. after saving that, navigate back into the drawable folder and add your animation.xml file there
5a. next navigate into the drawable/hdpi folder and add your animated images
6. also in the drawable/hdpi folder find and open up the shade_bg.png with your editor and make it 100% transparent (I actually skipped this step and just used a transparent image for the "normal" background)
7. now it's time to recompile your apk , following all the usual directions with that
8. enjoy your newly created systemui.apk with a pretty animated background. new and fresh and unlike anything before
that's it. done deal. it's super easy and fast and breathes life into true customization.
I used the stat_sys_download.xml in the drawable folder as my base for my animation.xml all I had to do was change the image names.
also you'll notice above - don't copy it word for word on the xml.
I did the "..." meaning whatever you decide to name your file.
Animated Status Bar LG - YouTube
ha - YouTube
(now for the fun)
ha - YouTube
