new optimus
Android Expert
A while back, when I was first learning how to flash the getitnowmarketing recovery, I was directed to install just the Android SDK tools and the and the Platform tools. Then I could run ADB shell under to push commands to the phone, such as doing all the commands necessary to flash the recovery.
This is what you read correct
joneidy said:To get service back and root you need to download adb. Go to Android SDK | Android Developers and download the file that ends on .zip. Extract it to your C:\ drive. Go to C:\android-sdk-windows and open sdkmanager.exe. After is open a windows will pop out click reject on all files except for:
Android SDK Tools and Android SDK Platform tools. Make sure USB debugging is activated (On your phone go to settings> applications>development and check USB debugging) Then open up Cmd and type the following: cd C:\android-sdk-windows\platform-tools.
When you follow those you end up with the folder on your hard drive inside that folder are the files I showed.
