Updated OP with links to 7.1.0 and latest Google apps.
Hmmm.... haven't seen either.
Glad it worked. Yup, takes a long time when you clear both caches.![]()
They changed it a while ago, and there's a new partitioning scheme. Your version of ClockWorkMod (CWM) is outdated. Update that, format /data per the instructions, and all should be well.[...] I have a suspicion that B&N is setting up Nooks different now because I never received an error formatting data before and now received it on 2 different Nooks.
Okay just to be clear, which order do I format once I'm in Clockwork Mod Recovery?
nevermind i redownloaded the zip and it worked
So, if he uses a different microSD card and has some apps moved to that microSD card, how would those apps get backed up? Would he have to hot swap his microSD cards and then just perform the Nandroid on the larger one that does not contain ClockworkMod Recovery flashed to it and then later copy that Nandroid to the smaller, recovery microSD card?. That is all that I could think of unless there is another, easier, way to pull that off.
