(Guide) How to update PRL
I just updated my prl from 3032 to 9033 and what a major change in speeds. I was getting at most times less than 512k down on 3032 and now I'm getting 4.8Mbps down on 9033.
Uploads were horrible on 3032 and now I'm getting usually around 1.7Mbps.
I downloaded qpst but in on vista and 64bit file does not install error out any help? Thanks jeff
Um...what happens when *228 dont work anymore and ur spc code does not work anymore on QPST!!????? ever time I put in it..it says invalid code?
did you try to uninstall and reinstall QPST? Could also try to reinstall your phone drivers
Did that and even, wipe ever thing on the phone and reflash firmware F..then D and still nothing..then upgrade back to firmware F..still stuck on prl 3028 :(
Alright idk what im doing wrong ive been trying to install qpst for the last hour and it gets to the end but stops and error pops up and cancels itself
Hi, i tried doing this but when i clicked add new port it didnt come up with a debug option thing. i selected developer usb option in the settings too ><
Got this will prl 9033 the 24th date
And this with 3032 the 25th date
How do I know which PRL I had before this horrible 3035 update? I'm pretty good at this stuff but can't remember it right now. I'm in the Orlando market.
My prl is 3036. Is this the latest (DFW, TX.)? If so does anyone know when it came down? I'm asking because my data was awsome (xbox, ps3, and laptop all riding the hotspot) until Sept. 1st. Now it's always lagging, connection t/o, etc. Can't even think about using hotspot. Was wondering if maybe a prl change was the blame.
