johnnyolivares
First you need QPST, I couldn't get any other version to work except 2.7 build 374. Downoad it, extract it, install it.
Download link: QPST 2.7.374.far
Secondly you need to know your MSL
If you don't, download MEID converter from the Play Store or go to whiterabbit.org/android. Enter your IMEI; your IMEI is found in settings>about phone>status, convert it and now write down that 6 digit number
1) Connect your phone to your PC
2) 2) Open Settings>Developer Options>USB debugging enabled (must be unplugged while changing the setting if stock).
[Let the drivers install]
3) Open QPST Configuration
4) Go to the Ports tab
5) Add the port that says Diagnostics
6) Press start client and choose Service programming
7) Make sure your phone is highlighted and press OK (from my experience the phone number will be wrong)
8) Press "read from phone" located in the bottom left
9)Enter your MSL
10) In the bottom right click on "Save to File"
[This will be your back up in case you accidentally did something you weren't suppose to.]
11)Go to Roam tab
12) Now browse for the PRL file you wish to install and choose it
13) Press write to phone, located on the lower left
You will get an error message saying your phone has stopped responding to read/write.... blahh blahh.... Phone no longer active on port x
Your phone will show that it has no service
14) Reboot your Phone
15)Your all done
To check go to settings>about phone>status
And here's a Video Tutorial
http://www.youtube.com/watch?v=5k-m4olAReY
You may notice i changed some steps in order for the phone to be detected, the reason being that my previous method wasn't working anymore but this did.
Credited for 9033 goes to n4zty
Other PRLs provided by Gman9831and 2GigayteSD
Special thanks to Sammy for correcting me on step 2
Thanks to SwoRNLeaDejZ for the video tutorial
2031.prl - 5.93 KB
9033.prl - 5.05 KB
2032.prl - 4.7KB
IF YOU WANT TO REVERT YOUR PRL DIAL *228
Choose option 5 or say update preferred roaming list
9)Enter your MSL
11)Go to Roam tab
15)Your all done
2031.prl - 5.93 KB
9033.prl - 5.05 KB
2032.prl - 4.7KB
