SwoRNLeaDejZ
Android Expert
So I figured I would write this up, because a lot of people seem confused about this, so it needs to be documented. When this phone came out, we were lucky enough to have root access relatively quickly, and even LUCKIER that the 2nd-init recovery works like a charm on our phone.
Once rooted, and on stock, in order to flash ANYTHING, it is required that you first install 2nd-init. You can check that thread out by clicking here: http://androidforums.com/motion-4g-all-things-root/665972-985hpakick-2nd-init-recovery.html
Now, once you have 2nd-init up and running, and you decide that it is time to check out some of the many "mostly stable" CyanogenMod 10 custom ROMs, what do you do? Well, pretty much every one of the most popular CM10 ROMs comes with complete, thorough instructions from the dev that created it. Even a simple search in the Motion 4G All Things Root subforum, will return a very informative guide written by Swainsmith82, all about how to flash a ROM on your phone, and even how to get the best performance out of your Motion once the ROM is up and running. You can check that guide out here: http://androidforums.com/motion-4g-all-things-root/763919-guide-rom-flashing.html
Now this is where the confusion arises. Once people achieve a beautiful setup on CM10, they apparently think to themselves "Hey, I need recovery so I can flash all these fixes and mods. I better install 2nd-init recovery now!". Well, that's not needed. When you flash just about any CM10 based ROM in this subforum, remember this one bit of information:
If you install 2nd-init over any of the CM10 builds YOU WILL HAVE TO UNBRICK. Plain and simple. You can try to replace the recovery you installed with the original recovery that was included in the ROM in the first place, but it's complicated, and I haven't seen a very high success rate (and the fact that you were absent-minded enough to install 2nd-init over a ROM that already included recovery, well, complicated may not be your strongest suit). So... KEEP IT SIMPLE STUPID. When you install a CM10 based ROM, DON'T INSTALL RECOVERY. It is a bad idea. You will receive a MorningCall security error, and will have to use the unbrick guide to get your phone back.
If you can not figure out how to access recovery, use this simple set of instructions below:
1.) Hold the power button until the power menu pops up.
2.) Tap REBOOT.
3.) Select RECOVERY if it is listed, to reboot into recovery. If RECOVERY is not listed, continue to 3a.
3a.) When you phone is rebooting, CONTINUOUSLY mash the VOLUME DOWN button, until Recovery opens up.
To reiterate: There is ABSOLUTELY no reason to re-install 2nd-init recovery over ANY CM10 based recovery in this forum. Don't do it. It's not needed, and it will result in a long, unbricking process that is not very fun.
I hope this helps to clear up any confusion
Thanks: Swainsmith82 for his ROM guide, 985hPaKicK for 2nd-init recovery, PlayfulGod BobZhome Johnnyl1111 and anyone else that has either ported or built any ROM for this awesome phone.
RECOVERY IS INCLUDED WITH THE ROM. YOU DON'T NEED TO INSTALL ANYTHING!!!
2.) Tap REBOOT.
