Done!!
Had to run HTC Sync (Doh)
then had to connect the phone to use HTC Sync, come out of debug mode, then back into it
While in the command prompt, you'll know its working as it will say
*daemon started successfully*
$ pm setInstallLocation 2
then the cursor will flash on a blank line, which is where you type the last instruction
then after pressing enter, the next new line will just show $
I am able to make it most of the way through the process but when I type "pm setInstallLocation 2" I get "[1] Killed pm setInstallLocation 2". I have looked everywhere I know to on the internet and have not found the answer for what to do.
I attempted this on a Linux machine on the Optimus Slider. Any help would be greatly appreciated. Thanks.
SUroot
it means after that $ after entering pm setInstallLoction 2 it is done already? I can move now the apps like FB YM Google Play store?? these apps cannot move to SD but the cost much MB in the phone memory
Hi there, thank you very much for this guide but I have a problem.
I have a Samsung S III running 4.0.4 android.
I followed the guide up without up to the point when I type "pm setInstallLocation 2" but when I enter the command in. It reply with a error message, "Error Unknown command 'setInstallLocation', and also with a list just below it.
Is there a way to revolve this problem?
any reply would be appreciate.
I have exactly the same problem..... did you resolve it?think ive sent myself insane doing this. have htc sync on laptop. downloaded & extracted rar file. dropped it into C drive. connected phone. opened black box typed as above, 'cd\android-sdk-windows\tools' straight after c:\users\user but keep getting 'the system cannot find the path specified.' blah blah blah.....!!!!! help it just wont work for me. but i cant see why as it seems so straight forward!
htc desire 310 getting error: unknow command 'setinstalllocation' fallowed by a list of packages . what can i do ?
