Root [Guide] Optimus V ROMS do flash with touchscreen working!!
No, I'm saying that my phone was one of the phones that wouldn't boot, so I'm using the one that works for the people who wouldn't boot. And I'm pretty sure that the one that was remade for the people that wouldn't boot is universal for all M's too (correct me if I'm wrong)
That's exactly what I'm saying lol....
lol I just now saw that I read your post in a way where I thought you said it doesn't matter if we use the original one....
I must be half asleep still xD
Okay, so I do think I have fully got it up and running. Now let's see what I replaced.. In /system/bin I replaced:
am
ami304d
bmgr
brcm_patchram_plus
hci_attach
fix_permissions
ime
input
monkey
pm
port-bridge
rild
servicemanager
vold
In /system/etc I replaced:
Folders:
bluetooth
dhcpd
firmware
permissions
ppp
wifi
wl
Files:
apns-conf.xml
dbus.conf
gps.conf
hosts
media-profiles.xml
resolv.conf
vold.fstab
In /system/lib I replaced:
Folders:
modules
hw
egl
Files:
libauth.so
libcm.so
libbluedroid.so
libbluetooth.so
libbluetoothd.so
libcamera.so
libcameraservice.so
libdiag.so
libdbus.so
libdss.so
libdsm.so
libdll.so
libgsl.so
libgstk_exp.so
libmiscta.so
libmmgsdilib.so
libmmipl.so
libmmjpeg.so
liblog.so
libnv.so
liboem_rapi.so
liboemcamera.so
libhardware_legacy.so
liboncrpc.so
libpbmlib.so
libqmi.so
libqueue.so
libril.so
libril-qc-1.so
libsensorservice.so
libwebcore.so
libwms.so
libwmsts.so
In /system/usr I replaced:
Folders:
keychars
keylayout
In /system/xbin I replaced:
Files:
hcitool
hcidump
hciconfig
And finally, in /system I replaced:
build.prop
(And you can't forget the boot.img, either.) But anyways, This should work for all Roms (Except ICS-based ROM's) from the Lg Optimus M, T, V, S, and the LG Vortex. Test this out, and give your feedback! :)
Here's the link to the finished ROM (of sorts) if you want it. signed_ICSandwich2.3.7_ThaUnknownArtist_01092012.zip - 4shared.com - online file sharing and storage - download
Edit: I'm not sure if the signature is still valid, so remember to disable signature verification.
If signature check is enabled, it will still say its invalid....
The original ROM is invalid via signature check
But if you unzip and rezip the original ROM it will not install at all if verifier is on or off...
I already replaced the files so I'm booting right now :D
Awesome. I kinda want to figure out why the ICS Rom won't install, though. It's probably something to do with the kernel?
Try replacing the boot.img with the boot.img from the ICS ROM that was made for our phone, they might be different boot.img, theres no way we're gonna get wifi becuase we need a wifi driver to be written first and it hasnt been written for our phone :(
We could probably get bluetooth working, though. maybe touch screen?
The touch screen seems that driver is in the boot.img, I may be wrong but as soon as we replaced the boot.img it fixed the touchscreen with the OV ROM on the OM
Yea it doesnt work right with ICS build, the boot.img is probably the reason it doesn't work correctly, it wasn't built correctly....
I'll try it later.
Mms doesn't work...but anyway everything runs good.
I think all you have to do is flash playfulgod's MMS fix for the optimus C, if there are any other issues besides MMS let me know so I can make the easiest guide to port m to the c.
