Root [GUIDE] Unbrick Attain
If i turn the phone on without holding volume down it goes into the "Android system recovery <3e>" and it says lfs done open fail at the bottom above # MANUAL MODE #
No I actually took it back to a hood metro store who didnt know anything about rooting and told them it started doing it on its own one day and lucky I just bout it within 7 days and theygave me a new one... Ive had about 12 android phones all rooted and have did plenty for others but this is the first time I actually bricked one... Im scared to try the zip allighned one now
The deodexed rom is cool. The thing is when you load the attain pit file into Odin it automatically checks repartition. You can either not load the pit file or simply uncheck it when u load it. I bricked the attain once through accidentally not unchecking the option. This method was simple and easy to unbrick the attain.
Hi guys,
First, thanks to Travis Antonio and Ben for helping us out with unbricking the Attain.
After following all the instructions I went back to Odin to flash Gasmod, but my computer is no longer recognizing the Attain. In addition, I've tried it from another computer. I've tried forgoing using Odin to flash, and tried installing the Google Play store using the Android SDK, but even adb doesn't recognize the device.
Any suggestions?
Much appreciated!
you shouldn't need to use a pit file odin automatically retrieves it when flashing
I am bricked , i try to download the file from 4shared, but it doesnt work, can you please help me ??:mad:
what if phone was brought back to life but boot animation repeats itself forever??right at the part were metroPCS logo then samsung logo appears.
Try running the 2.3.6 update so it erases everything and put you back to complete stock. I don't see why that wouldn't fix that issue
i think im on my 3rd time doing this. but i keep ending in a boot loop. should i factory reset n wipe data when it give s me the option. also the phone shows recovery verification faild is that okay?
OK so i got my computer to recognize my device, and found a Heimdall Suite link that worked. as of right now my phone is stuck trying to reboot itself... i followed all of the steps and am now stuck.. Please Help!!
After selecting the AttainFix.tar.gz for Heimdall Suite I get "Unexpected error whilst extracting package files".
Re-downloaded the AttainFix file and it loaded just fine
Help, I have an Attain that has an unknown baseband. I have updated it. I have been working on it for hours and finally got it to take the Samsung Simple Update. The phone still refuses to connect. It was rooted and I had hoped the update would bring it back to some semblance of its original self. I am getting an untouched Attain tomorrow and need to know if I can copy the firmware from this second Attain to repair the first. If so, how do I copy the firm ware without rooting the phone?
You can't copy the firmware. After running the update all attains end up with the same firmware so I doubt it would change anything even if you could. Did you change some internal setting?
