Happened to me too
Is the entire cab downloaded?
Upvote
0
Happened to me too
Anyone clocked at 1.2 GHz want to try this???
And don't unplug the phone until its booted!!
Optimus Regard users, use this guide:
http://androidforums.com/optimus-re...-unbricking-unrooting-optimus-regard-kdz.html
Don't like reading? Skip to the end of this post for a YouTube video on how to do this. I warn you though, read everything at least in the video before you begin.
Right now it is likely that anyone here will brick due to the phone having a secured bootloader. Flashing this firmware is your best shot at fixing any brick from removing stuff with root permissions.
Another thing I know is that some phones have been clocked at 1.5 GHz and others clocked at 1.2 GHz.
If your phone was clocked at 1.2 GHz, this firmware will clock you at 1.5 GHz!!!!!!!!!!!!
That's a good thing
-Confirmed here: http://androidforums.com/motion-4g-...t-getting-back-stock-kdz-wip.html#post4902686
This firmware link is from a serial number of an LG Motion 4G clocked at 1.5 GHz. None of us know if LG made two separate firmwares with some phones clocked at 1.2 and others at 1.5 or if phones that came with 1.5 was a simple typo by LG. So this firmware WILL clock you at 1.5GHz
Instructions:
Download firmware from here: Official Motion 4G MS77010c_03 Firmware - Android Forums
Download the programs to convert and flash firmware: KDZ_FW_UPD_EN.zip
Download the new drivers: https://www.box.com/shared/32c5t7fj2w8xcwr0krjo
How to get into emergency mode:
Hold Power+Volume Up+Volume Down
To get out of e-mode, pull battery (do not do this while flashing firmware!)
Picture of emergency mode (Thanks to Sepero):
Thanks to DarkStarONE for how to enter emergency mode.
Before you start flashing firmware, please make sure you charge your battery for at least 30 minutes.
These are the instructions to convert the cab to a KDZ and flashing it:
- Install phone drivers
- Install msxml.msi
- Disable antivirus software
- Open UpTestEX_mod2_marwin.exe
- Wait for the program to open
- Look for "Encrypt cab file to kdz file"
- Click the folder icon
- Choose the location of the cab you downloaded for MS770 firmware
- Encrypt cab -> kdz Program will freeze up. DO NOT EXIT until program says Done!!! Otherwise it won't finish converting.
- Close program
- Open KDZ_FW_UPD.exe
- "Type" choose CDMA
- Choose in "Phonemode": Emergency
- Click the folder icon and choose the kdz file that UpTestEX_mod2_marwin.exe just made.
- Click Launch software update and enjoy!
If you are stuck in a bootloop, do this (it will factory reset by following this):
Phones don't fix themselves.
Please donate.
Thanks to Crocididdle for this video:
How To UnRoot Or UnBrick Your LG Motion 4g - YouTube
umm im in a boot loop at da metropcs boop and i cant get into da factory reset screen wit vol. down and power
i have lg optimus lte 2. i forgot my password. and there is no way to go into recovery and wipe all data. i tried to update cell via kdz i got it but i didnt open the lock. even firmware is upgraded but security code is still there....
plz help me out wht to do to wipe this....... plzplzplz
I am stuck on trying to convert the cab file. After I convert I get a file with a white box that is a .kdz file. When I use this file and click launch software update I get:
[R&D Test Tools Log File]
20:13:06 : Launching SW update
20:13:06 : Unpacking KDZ
20:14:07 : KDZ file extraced
20:14:08 : Extract file error
20:14:10 : ===FINISHED===
now I am bricked. I can get the lights on the back, home and menu keys to flash on and off but that's all. I had the phone plugged in and just saw it go blank.
update:
I got it to boot up. I and going to use the kidz file instead of converting.
Sammy...can we use this marwin program to build a CAB or KDZ?...or inject something into the CAB or KDZ?
