androidesire
I am o2 germany, software number 2.14.207.1
thats interesting as the sw version for o2de is the same for o2uk either try O2___102 (notice 3 underscores) or O2___001
. This worked for the mtd0.img . Thanks Rastaman.
But the problem remains.
At step 4 , i typed the command in terminal emulator correct and got the message:
usage: /data/data/flash_image partition file.img
Rebooted my phone hoping usb brick is gone.
But nothing again.
Surely i make something wrong, but what ??
Great post! I've tried a ton of unbricking guides only this one really works....after that i simply typed this command in terminal emulator
"su
/data/data/flash_image misc /data/data/mtd0.img"
Rebooted my phone and voila usb brick is gone htc sync,usb tethering,sd card mount,charge everything is working and now i am rooted and s-off again![]()
I am stuck on the hex editor, where do I change the CID? all I see is lots of numbers. Yes, I am a BIG noob, but I've managed to save my desire this faronly a little way to go!
Hi,
Can't get phone CID because my usb brick does not let my see phone using fastboot. Tried the rest but can't get it back. Anyway to get phone CID without fastboot?
tx
no you can do this on rooted/cutom rommed devices, this is for unreooted and rooted devices.Just joined your Forum to ask a few questions. Forgive me if they are not in the right place. I had my rooted HTC Desire USB bricked recently. I did not know what it was. Could not get any access to SD card to restore any of the ROM I had with Rom MAnager. Anyway I found this command on line fastboot oem enableqxdm 0which let me have my SD card back. All is fine apart from the fact that my bluetooth won't turn on and the battery life (which wasn't great any way) is now a lot worse. Today I found that I should have done the second part of the process with fastboot oem eraseconfig command. My question really is - do I have to go back to the original unrooted version of my HTC Desire to go through the process described at the beginning of the thread or can I do it with my current CyanogenMod?
Can you boot to recovery?i installed everything but i can't get the htc to be recognized in adb shell or fastboot...all i get is waiting for device ( IT IS S-OFF, AND I CAN SEE AND USE THE SD CARD)
the symptoms i get are that i can not connect to the pc by any means, i don't have any signal and no sound
PLEASE HELP ITS DRIVING ME CRAZY
i can't succeed to copy those files in phone memory
