Shrikant716
-----ROOT AND INSTALL CUSTOM RECOVERY ON MICROMAX A75 WITHOUT PC-----
Procedure:
1.Download the following package
:::::link:Root_&_recovery_for_MMX_A75 - Download - 4shared
2.Extract the package and place the three files in the package to the root of your sdcard with any zip extractor app.Download it from PLAYSTORE
3.For those who already have root access use root explorer. Download the root explorer from here and install it.
:::::link: https://play.google.com/store/apps/details?id=com.speedsoftware.rootexplorer
4.Now reboot in to recovery mode.
5.select update zip from sdcard and select the superuser.zip.(it will get flashed and then select reboot).Now your mobile is rooted. You can see superuser app in menu.
6.Now install mu73.apk and open it.
7.After opening it superuser asks you to allow the app.Press Allow....Next Tap on the "flash recovery from sdcard"......and next tap on the recovery.img file.(It'll automatically reboots in new custom recovery).
8.That's it you have installed custom recovery.
Disclaimer:
This method had WORKED for ME.
Am not responsible if your mobile is BRICKED.
DO AT YOUR OWN RISK.
IF YOU DON'T WANT TO TRY THIS METHOD, THEN YOU CAN USE ANOTHER METHODS PRESENT IN THE FORUM.
Thank you,
Regards
Shrikant......
Procedure:
Disclaimer:
Thank you,
Regards
Shrikant......
