Hand swipe
Hi I beleive you can swipe your hand over the S4 then it turns on and displays a status etc - how does one go about doing this please?
Hi philsworld, and welcome to Android forums!
I believe this is accomplished by going into settings, clicking on "my device", and then choosing the "motions and gestures" setting, then make sure that you set the "air gesture" toggle to show the green "on" position.
I hope that helps you.:)
