Help Handcent/sms help
Michelle666
I've downloaded handcent and much prefer using this to the HTC message app (can't stand having everyones contacts, emails etc)
Little problem I've just noticed though. When I got a text it bleeped twice, once for Handcent and one for HTC Messages...how do I disable HTC's app, and just use Handcent (if this is possible!)
Just go into settings on the stock app and disable notifications.
open up the app called "Messages" from programs then press "menu" then "settings" then untick "Recieved notification"
That will sort you
try to send something or reply to a sms. It will ask you to choose with which application will do it. select handcent and check the option below so it will never ask you again
Just a note though.
Are you on droid 2.1, or have you upgraded to 2.2?
The only reason I asked is that since I rooted, and upgraded with a custom ROM, my Handcent notifications have stopped working. As a result I'm using the stock app for the notifications.
As I said, I'm using a custom ROM from MoDaCo, so it MIGHT be a unique problem to that, and the genuine HTC ROM MIGHT be fine.
Just something to bear in mind.
Andy
hi there! I'm from the philippines I have a globe prepaid sim and my phone is a galaxy ace. anyway I used to use handcent for my sms but i have noticed a problem with it. whenever i txt using it like for example i apply for unlitexting which costs 15php and i have 50 load the remaining balance that i would have is 35 but when i txt using handcent it automatically becomes 0 and I even tried to exprement with it i had unli texting for 2 days i had 5 php load balance i texted with the messaging app which is with the galaxy app and i checked my balance and it's still 5. but when i used handcent it became 0.
pls help i really want to use handcent. thanks!
