Handcent SMS question
tpdtopcop
Member
Hey guys for those of you using Handcent SMS, can you disable the regular htc messaging? When I get a text now I get two tones that I have received a text message one from the htc built in messaging and one from handcent.
Thanks
topcop
Yes . It is located in the stock messaging...while in messaging press menu and then settings. Disable notifications. Check out the sub forums above this "general" area ....alot of good info in there. And remember....search is your friend!
