thebryceee
Android Expert
Does the roms we use on here (mobster/midnight/harmonia) require the later bootloader? I'm also at work and won't be able to delete the file once loaded.
Edit: NVM
Edit: NVM
If you are running a ROM like Harmonia (that is what I was running) it should boot back up just fine after the install and then use a file explorer to remove it.
I can confirm AOKP M6 boots with Anthrax kernel 3.0.2Great work, Krowley!
Edit: ha! It's been so long since I flashed an AOSP rom that I completely forgot to flash GAPPS.
Haha nice. Do you have a link to that rom? I'm gonna be flashing a variety of stuff today, because I can now![]()
If we downgrade our hboot through this, will it also downgrade our PRI?
Jelly bean was fast as hell but buggy obviously, being in Alpha.
Running CM9 now...I forgot if anthrax 3.0.2 would work with this.
Niiice man, I was so close to trying this a couple weeks ago but couldn't risk the brick.Props!
Or did you modify it as well,(couldn't have done that) either way thanks
Changing the Hboot won't affect the other roms we already have and our backups? I am on midnight rom but also have a harmonia and the stock backed up.
Lol is there no icon for 4G for DT CM9?
There is a widget icon in the notification bar and there is a full menu in settings if you select more under wireless & networks.
