Root HBOOT question. Need help
stefanl
in my attempt to install the MUIU Rom I am having trouble upgrading my Hboot to .92
Ive downloaded it from various links provided, put it in the root of my sd, rebooted into hboot, waited, saw it check the PB31IMG.zip.....then nothing. It doesn't prompt me to do anything....
any suggestions?
Thank you
It probably won't load if you haven't formatted your card to fat32 at some point. Also, you don't need to update hboot. You'll get a fail notice when loading the Rom but reboot into the Rom and all is well. Many of us, myself included, have done this with no problem. I'm still on 0.77.
What are you talking about? Reboot into the Rom and all is well? So you can install MIUI with 0.77?
Yes you can.
You'll get an abort message at the end of the loading process in Clockwork. Then choose the reboot option in Clockwork and it boots up the Rom just fine.
