mannysdroid
Hi All
First post here and fairly new to rooting. I have a HTC Desire GSM. Now I've managed to root the phone with s-off after trawling many forums. The reason being that there are so many variations of how to get to the end result.
Apologies if the following has already been asked but I couldnt find any straight forward guides/answers.
I've rooted using unrevoked and s-off using revolutionary.
Hboot:
I havent actively looked to flash a new hboot in the past and currently mine shows revolutionary at the top - i assume i still have the stock version?
It appears that flashing a new Hboot would gain me some more space internally due to the way it is partitioned is that correct?
In terms of how to flash the hboot I have read a number of guides all varying. Can someone tell me how to do it in the safest way - so far i have found android flasher, simply saving the .zip file to root and renaming to .img and then going into hboot and it will do the rest. I have then seen another method via android sdk. I'm not entirely sure how to use either but a guide on them would be great.
SD partitioning - I have done this previously by going into recovery with cwm and doing the partition - i assume this gives me ext2? However, if i flash a new rom do i need to re-partition each time and then recover data via titanium etc? The reason I ask is that I flashed miui all appeared to be working ok. I then flashed the insert coin rom and it was showing I only have 137mb internal memory free whereas i thought it would automatically use a2sd+?
I wanted to flash the cool 3d bliss rom to my htc desire but i couldnt find any instructions especially on how to gain the additional internal memory.
Not sure if all of this makes sense
Any help, greatly appreciated
Thanks
Manny
Hboot:
Thanks
Manny
